I have successfully installed one agent in a k8s environment. There I have 2 applications and a Postgres cluster. The first application is tomcat based and the second one is pure java one. When I call the endpoints of the tomcat application I could see the SQL calls in the databases tab in the dynatrace dashboard. From Transactions and services / <my application> I could also see the connection to the database and the monitoring is working as expected. The second application is java one as I previously said but when I examine it I couldn’t see a connection to the database (
) and any SQL queries from the pure paths but in the Postgres command-line client, I could see that the calls successfully reached the DB and impacted the schema. The two apps share a common project which makes the calls using a JDBC driver. My question is why I am able to see the calls to the DB from the tomcat app and not from the pure java one.
