Postgresql extension - Authentication GCP SA
We have a large-scale PostgreSQL monitoring deployment use case involving several hundred databases.
Currently, the configuration only supports a username/password connection and AWS Workload Authentication (which is not applicable in our case).
For obvious security reasons, we cannot use a single password across all databases.
In addition, the extension only supports up to 100 monitoring configurations, which is currently blocking us.
When do you plan to support authentication through GCP (and Azure) using service accounts?
Clément
