Whether you’re asking a question or jumping into an existing conversation, this guide covers all the tools available to you as a contributor — from starting a topic to formatting your posts exactly the way you want them.
Starting a new topic
Click + Ask a question on the main page (or New topic in the top right of any category page).
Write a clear, descriptive title — this is the single biggest thing you can do to help others find your post later.
Write your message in the editor, choose the right category from the dropdown, add any relevant tags, and click Create Topic.
Tags now work across categories, so make sure to tag your posts correctly if you want others to find them easily. Anyone browsing or following a tag will see your topic, whichever category it lives in.
Replying to a topic or post
Press any Reply button to open the editor. There are two ways to reply:
Reply to the whole topic — use the Reply button at the bottom of the page. Your post appears at the end of the thread and notifies anyone watching the topic.
Reply to a specific post — click the arrow button beside that individual post. Discourse links your reply directly to theirs, so the context is always clear even in a long thread.
You can keep reading or navigate to other topics while the editor is open — it stays docked at the bottom of your screen.
Drafts are saved automatically. If you navigate away or close the editor, your draft is waiting for you when you return. You’ll see a draft indicator on the left sidebar (under categories list) when you have unpublushed drafts.
Quoting someone
To quote a specific piece of text, select it with your mouse or finger, then press the Quote button that pops up. You can pull in quotes from multiple posts or multiple people in the same reply — just repeat the selection. Much cleaner than copying and pasting entire messages.
@Mentioning someone
Type @ followed by someone’s username to notify them directly. A dropdown will appear to help you select the right person. They’ll receive a notification that you’ve mentioned them — useful for looping someone in on a conversation they might have missed.
Liking a post
Click the
heart icon at the bottom of any post to like it. A simple way to acknowledge a useful answer or a good contribution without writing a reply.
Editing your post
Made a mistake? Click the
pencil icon on your own post to edit it. Discourse keeps an edit history, so the community can see what changed if needed. You can edit at any time — there’s no time limit.
The editor toolbar
Discourse’s rich text editor has a toolbar covering the most common formatting options — bold, italic, headings, bullet lists, numbered lists, links, and image uploads. For most users, the toolbar covers everything.
If you prefer writing in plain text, you can switch to Markdown mode using the toggle at the top right of the editor. Discourse also accepts simple HTML and BBCode — all three produce identical output:
**This is bold** (Markdown)
This is bold (HTML)
[b]This is bold[/b] (BBCode)
For a quick Markdown refresher, the CommonMark 10-minute tutorial is quite handy (and it’s free!).
Quick Markdown reference
| Format | Syntax |
| Bold Italic Link Heading Bullet list Numbered list Blockquote Horizontal rule Table Collapsible section |
**bold** *italic* [Link text](URL) ## Heading - item 1. item > quoted text — | col1 | col2 | [details=“Title”] content [/details] |
Code blocks and syntax highlighting
To share code inline, wrap it in backticks: `code here`
For a multi-line code block with syntax highlighting, use triple backticks (```) and specify the language in the dropdown on the right side of the frame:
An example:
function greet(name) {
return \`Hello, ${name}!\`;
Discourse supports syntax highlighting for most common languages — JavaScript, Python, Ruby, SQL, Bash, JSON, YAML, and many more. Just replace javascript with your language name.
That covers everything you need to post and contribute effectively. If you want to go deeper — keyboard shortcuts, bookmarks, or notification settings — take a look at the other guides in this series.
