We’d like to have an alerting metric for publish vs delivered messages and in Data Explorer is fine but when we try to configure it in Anomaly Detection metrics I see this message:
We are using Managed and not SaaS.
Your pictures are not readable well, but i used my sherlock holmes skills to suggest you to remove “:fold(avg)” from your selector, because anomaly detection requires multiple values instead of single.
yes, indeed but the expected result is when I am using :fold(avg). Is there a way of how to workaround this requirement for multiple values? ![]()
Fold transformation produces single value for specific timeframe. What is your required timeframe for evaluation in anomaly detection?
10min
Then try :rollup(avg, 10m) transformation.
I’ve tried with rollup and all possible transformations but nothing give me the expected result. Probably we are going to achieve it with a custom script and log monitoring.
