I’m using the dynakube.yaml and kubectl to instrument my kubernetes cluster. The kubernetes cluster is an ondemand setup - which means its getting provisioned and de-provisioned every day.
Now I have an issue with re-adding the cluster with the same name in dynatrace, after installing the dynatrace deployment I get insight into hosts etc. but no cluster is registered for the kubernetes monitoring.
If I change the name, I’ll get a new cluster immediately.
How can I deploy a kubernetes cluster fresh and “join” it to dynatrace as the same cluster?
At host level there is this “--set-host-id-source=fqdn” for example.
