SalesForce Extension
I was wondering about the salesforce streaming API extension and if there was some demonstration or a trial. So that the customer can be aware of precisely the kind of monitoring they will be getting instead of going in blind. Let me know if you help thanks!
Hi there, you can download the extension going to the Dynatrace Hub webpage and search for Salesforce https://www.dynatrace.com/hub/detail/salesforce-streaming-api/?query=sal
