SaltStack integration
Would be interesting in seeing how many folks are using SaltStack in their environment and are adding specific salt grains as metadata to Dynatrace to enhance their visibility?
Hi @John_McLaughlin
Currently,  for deployment orchestration with Dynatrace you can use Ansible and puppet, soon Chef
I was investigating about SaltStack  and discovered that it really is a powerful tool, I share with you a table that I have found
I recommend you to create a post in  Product ideas - Dynatrace Community  about that.
It’s interesting SaltStack
I hope it’s helpfull :flexed_biceps:
Product idea has been raised → https://community.dynatrace.com/t5/Product-ideas/SaltStack-Integration/idi-p/243889
