Hi
Please note am facing a case, that there is detected application contain a lot of pages, each page is a separate application to different team, any chance to separate each page to different frontend application
Eslam
Hi
Eslam
Yes, application detection rules can be on url path too. Just don’t forget if a user will access multiple applications, the cost for his/hers session will be higher, see Understand and manage consumption for Real User Monitoring (DPS) — Dynatrace Docs
Hi Julius,
Thanks for your reply, but i already did that but there is no traffic or session detect to the created application
Eslam
Hi @IslamEsmail
Are you seeing no traffic at all (and RUM isn’t being detected), or is traffic being detected for only one application? If it’s the second case, please make sure the order of the rules is correct.
Best Regards,
Hamdy
