Summary: This post explains how to request or configure a vanity URL for a Dynatrace environment. It covers eligibility, required settings, and limitations depending on deployment type and account configuration.
There is an option in Account Settings to change environment details including Time Zone and Friendly name and Vanity URL.
We have a couple of customers who wish to change the unintelligible prefix on their environment URL to reflect their corporate name, say for example myCompany.live.dynatrace .com.
I thought the Vanity URL was to achieve this but on save I get an error “Unable to Save Changes”
Is this achievable in Dynatrace because it seems like a simple thing to offer to customers for their branding purposes, rather than a sequence of alphanumeric characters?
I was looking for the same information. I believe it supposed to enable entering a ‘friendly name’, so that next to going to the url https://<tenant-ID>.live.dynatrace.com/ you could use https://friendlyname.live.dynatrace.com/.
I can not find anything on ‘Vanity URL’ in the documentation. So, if someone of Dynatrace can shed some light on this, that would be great.
Hi @fstekelenburg have you tested with the friendly name and it works?
What is the difference between a friendly name and Vanity URL because friendly name accepts spaces and I do not believe the environment url will work with spaces
Can Anyone from Dynatrace provide information on this?
No, unfortunately like you I get the error “Unable to Save Changes”. Sorry I forgot to mention that.
I think maybe the function is not yet available, or you need support from Dynatrace ONE team to set/enable it. I reckon you can open a chat to ask.
Hi @echwallah, based on my own experience, you are correct in terms of what the vanity URL is used for - you can set the vanity URL if you have the necessary privileges on the tenant via the Account Management portal, I’ve done this successfully before.
The vanity URL does not change the tenant ID, so nothing is affected if the vanity URL is set - it is merely used for a friendlier URL, something that is easier to remember for the end users e.g., like you mentioned clientname.live.dynatrace.com is easier to remember than abc12345.live.dynatrace.com
However, you cannot have spaces in the vanity URL name; you can use a dash (-) and I assume an underscore would also work, but I have not tested it.
Note: be VERY careful when setting it, because once set, you cannot change it again! So, please make sure the client understands this prior to setting it and that they approve the name that is to be used.
The friendly name is used in the environments drop-down (dude icon, top right when logged into Dynatrace) and is just a display name that would be helpful if you have access to multiple tenants, like in your case where you support many clients. Friendly names can have spaces.
UPDATE: from personal experience, it seems that term license tenants’ vanity URL can be set via the AM portal, but trial/POC licenses not.
However through the AM Portal changing the url displays an error that “..Cannot Save changes”
Also, Special characters are not allowed.
After having a conversation with in-product chat they mentioned that this has to be requested and applied internally hence am also wondering how yours worked.
I believe we might need DT to clarify generally how this works
@fstekelenburg Thanks a lot for this information. I am with multiple clients where facing issued for changing the URL as per their own business name. However, i got the path now.
As far as I’m aware this is not currently supported. If one doesn’t already exist consider opening a product idea or you could reach out to support to see if they can provide more information.
