Summary
This troubleshooting guide will help you look up the SQL query that is running to pull data for a particular metric for a SQL extension.
Problem
When working with metric data generated by a SQL extension sometimes it’s useful to know the SQL query that generated the metrics to understand that data batter.
Troubleshooting steps
- Go to HUB tile → Download (Release Notes / expand version → Download Version). Read file extension.zip/extension.yaml from the zip file.
- Find sql* section (sqlOracle, sqlPostgres etc)
- Look in the extension.yaml for a metric key. It will be besides a specific query. For example:
interval:
minutes: var:query-interval
query: >
SELECT
CONT.NAME,
CAST(CONT.OPEN_TIME AS DATE) AS OPEN_TIME_CASTED,
CONT.OPEN_MODE,
CONT.RESTRICTED,
INST.INSTANCE_NAME,
CDB.CDB_NAME
FROM
GV$CONTAINERS CONT
JOIN GV$INSTANCE INST ON INST.INST_ID = CONT.INST_ID
CROSS JOIN (SELECT sys_context('USERENV', 'CDB_NAME') as CDB_NAME FROM DUAL) CDB
metrics:
- key: com.dynatrace.extension.sql-oracle.database_topology
value: const:1
