Workflow - Corelate problem trigger
I have a basic query:
fetch events,from:-2h
| filter event.kind == “DAVIS_PROBLEM”
| filter matchesValue(event.category, “availability”)
Now I want to corelate all the availability events with below scenario’s into workflow and send it to integration -
  • Based on Tag - abcd:123
  • Based on title
Motive: instead of multiple events, we should have one as a parent.
Thank you in advance.
MH
Maybe this recent video provides you some idea.
Best regards
Thank you, i checked the video.
Its simple 1:1 but I want as 10:1. Basically, corelation.
