Hi all ,
I want to ask about Event like this picture below :
is this Events on process can put on Dashboard Dynatrace?
because after we check it . it seems no metric related to this event.
regards,
ridho
Hey @cyanogen
If you’re on Dynatrace SaaS then the events that show up in there should be able to be queried with DQL to then be put on dashboards however you like, they should be in the events table. I’m not sure if they’re all available but I know I have found a few in the past.
If you need these events on classic dashboards or you’re on Dynatrace managed then I am not aware of a way to do that without setting up a script to query the event API and re-ingesting them as a metric in some form. Depending on the specific events you are interested in there might be metrics related to them but I am not familiar with a generic events metric.
Hope that helps!
