So when I tried to deploy OneAgent for AWS EKS, I got this error:
- cluster-name-activegate-0
Events:
Type Reason Age From Message
Normal NotTriggerScaleUp 98s (x121 over 21m) cluster-autoscaler pod didn’t trigger scale-up: 2 max node group size reached
Warning FailedScheduling 69s (x42 over 21m) default-scheduler 0/3 nodes are available: 3 Insufficient cpu. preemption: 0/3 nodes are available: 3 No preemption victims found for incoming pod.
Is there any resource requirement for this Dynatrace to be able run in EKS?
Thank you in advance
