Open Q&A
Supporting of OEL by OneAgent
Hello, community!
My question is regarding supporting of Oracle Enterprise Linux (OEL) 6.7. As known OEL is based on RHEL and core of OEL equal RHEL.
In our documention i see different versions for supporting RHEL (5.4+) and Oracle Linux (6.8+)
In fact is it possible to install OneAgent on OEL 6.7? Will it work? any limitations? or it not supported?
Dmitry
skrystosik
Even if you will install agent on unsupported version and it will work, you may be out of support in case of any issue here.
Regards, Sebastian
Community Team
Community Team
Red Hat Enterprise Linux is supported by Dynatrace in all versions above 6.x:
Red Hat Enterprise Linux 6.x, 7.x, 8.x x86-64
7.x, 8.x PPCLE
6.9+, 7.x, 8.x s390x
7.4+, 8.x ARM64 (AArch64)
And Oracle Linux is supported in all versions above 6 (6.x, 7.x, 8.x)
Technology support
If you have any questions about the Community, you can contact me at [email protected]
