24 Nov 2019
10:42 AM
18 May 2023
03:33 PM
Michal_Gebacki
When uninstalling the ActiveGate on a Linux box the uninstallation process backs up the installed custom plugins:
05:29:48 Backing up installed custom plugins...
05:29:49 Custom plugin backup finished
Where are these plugins backed up to?
I have also noticed that when you reinstall the ActiveGate on the server, the Remote plugins previously deployed are automatically restored to the /opt/dynatrace/remotepluginmodule/plugin_deployment directory. I would still like to know what the backup path is though...
14 Jan 2020 10:12 AM
They should be kept in installation directory:
https://www.dynatrace.com/support/help/shortlink/sgw-uninstall#after-uninstall
