23 Oct 2020
02:12 PM
11 May 2021
12:07 PM
Hi all,
We need to open Remedy tickets from a Dynatrace managed. Did anyone do something like that before?
Regards
R12
23 Oct 2020
02:25 PM
11 May 2021
12:02 PM
A while back I did something for this, here's a PDF with what we had working. If your Remedy is configured differently you likely wouldn't be able to use exactly this but it might help to start. Pa y attention to the headers as well.
Also note that since Dynatrace sends notifications for the opening and closing at least you would end up with 2 tickets unless you either use some sort of middle tier to intercept the later updates or you have configured Remedy to identify the 'updates.' I never saw that working but was told it is possible.
21 Apr 2021 11:33 PM
Hi James
Can you please share the pdf with me.
When I consult the link it sends error 404
11 May 2021 12:05 PM
Hello @jemartineza
I've fixed the link to the pdf in James' comment, you should be able now to access it correctly.
Also, instead of clicking on the link, you can also click on the file preview at the bottom of the comment, to see it directly in the Community:
20 Jan 2023 05:19 AM
For standard infra monitoring, can we monitor custom high CPU usage and it should trigger alert and integration with remedy.
Without installing one agent on the host (AG host ) I have created events without using tags I am facing problem at integration
Not getting INC in remedy but problems are detecting onto the Console.
Do you have any suggestions on this ? How can I fix this issue
