20 May 2026
04:36 AM
27 May 2026
01:28 PM
AgataWlodarczyk
Hi Is there any guide or how can I create dashboards using MCP?
27 May 2026 04:20 PM
Unfortunately, this is not possible yet. In which context would you like to create dashboards...?
If you are working in an IDE (like Claude Code, VS Code, Cursor... ) then you could give dtctl a try - it allows you to create and update dashboards with an agent from outside Dynatrace. It works great in combination with the MCP server. I use it a lot, and its capabilities are really impressive.
For more information, have a look here: https://www.dynatrace.com/news/blog/dtctl-the-dynatrace-observability-cli-thats-built-for-ai-agents-...
You can install dtctl from GitHub (where you also find comprehensive documentation and supporting skills): dynatrace-oss/dtctl: CLI for managing Dynatrace platform resources - built for humans and AI agents ...
