Alerting
Alert Notification for Custom JVM Metrics
ag14341
Newcomer
HI,
I have enabled custom JMX metrics by uploading plugin.json
under Settings/monitoredtechnologies/customextensions which shows metrics in %ge
Now i am looking for Alert if the metrics of custom  JMX metrics is beyond 50 %. how to get the alert.
I am able to see the metrics in ANamolyDetection-->Custom events for alerting-->Create custom event for alerting.
But i dont see any option to select the %ge as threshold limit where i can generate alert where if Metric percentage goes beyond 50%, i am not able to recieve any alerts.
Could you please help in this regard.
MBR.
ChadTurner
DynaMight Legend
DynaMight Legend
If that unit being Percentage, isnt available via the Custom Event for Alerting then a RFE will need to be put in place for that. Since you do not reference what jmx alert you want i cannot confirm if Percent is present or not.
-Chad
