Alerting
Alert Setup using Remote Unix Monitoring
AbbieA
Participant
Any tips and guides on how to setup alerts for Solaris in Remote Unix Monitoring. Specially for the monitoring of mount disks. Thanks.
3 REPLIES 3
Yosi_Neuman
Hi @AbbieA
You can create a metric event on the mounts and disks metrics that this extension collect
HTH
Yos
sujit_k_singh
Champion
@AbbieA As suggested by @Yosi_Neuman is the best solution, as i have implemented the same, created metrics events as per the documentation and works perfectly.
AbbieA
Participant
Thanks, it works!
