Alerting
Anomaly Alerts for 4xx alerts by request/endpoints in Dynatrace Classic
harinhs1
Visitor
We want to get alerted on anomalous behaviour in our 4XX errors. In the particular, the ones affecting out front end and middleware.
Constraints:
  • We do not want to define 4XX errors as server-side as this will affect the failure rates and cause poor error detection to the mix of business/expected errors inherent to 4XX responses.
  • We want to minimize the number of CSMs and Metric Events, including the volume of data ingested by a Metric Event
  • Any solution has to tell us which application, service &  HTTP response code is driving the issue  (ie dimensions to split)
    • Preferably we can drill down the specific request/endpoint
  • Preferably, when an increase in 4XX errors occurs, a solution would be able to tell us what request/endpoint is driving the issue.
  • Strong preference for anomaly detection vs static threshold
Any suggestions for the recommended solution to the above problem statement in Dynatrace Classic, we do not have Grail/DPS.
Hari
0 REPLIES 0
