Alerting
Create Problem/Alert based Request Attribute for HTTP 200 requests
cando
Participant
Hi Dears,
I have some requests and i retreive the output based on the PHP method
Its working fine and i get the right Request Attribute
No I want to create an alert based on a specific text.
On the Global - Failure Detection Parameters, i added a new rule
With a custom error :
But after activating my failure detection rule
Its seems that ALL my requests with HTTP 200 are seen as Failed
The this is that i just want to get alert/problem IF this request argument is present AND with the text condition i defined, regardless of the HTTP code
thanks for your help
4 REPLIES 4
Peter_Youssef
Leader
Hello @cando
You can change it from contains to equal and check the output.
BR,
Peter
Peter_Youssef
Leader
Hello @cando
  • You can also ensure the configurations are applied on the intended services not on global level.
  • You can narrow the scope via proper adjustment to the management zones and alerting profiles to avoid irrelevant alerting.
Thanks.
Hi Peter, thanks a lot. I disabled the custom error on the global leved and set it on the service level.
It's now working as attended.
thanks a lot for your time
Hello @cando
glad to hear that, all the best.
Enjoy delving into Dynatrace innovations 👨‍💻and best practices 😊
