Alerting
Create log metric with custom dimension
henk_stobbe
DynaMight Leader
DynaMight Leader
Hello all,
I want to add a log metric with a custom dimension. I figured out that you need a log processing rule with a matcher and a processor. So far so good. But what will be the new dim name?
Use case example, monitor if there are more then x failed login attempts from a specific IP => need IP as a dimension as input for the metric event?
Any suggestion please?
KR Henk
3 REPLIES 3
Malaik
Leader
Hi @henk_stobbe
If you want to add a dimension,
in the metric extraction you should add it:
Sharing Knowledge
Hi Malaik,
Thanks for your reply, but what todo if the dimension is not on the list?
KR Henk
You Should create it as an attribute,
Or from the processing rules.
Sharing Knowledge
