Hello!
Is there a way to propagate custom alerts severity to AI processed problems?
For example, define kind of relation between core switch CPU utilization (custom device and mentric) and whatever object or service we know can be affected by it.
Sounds quite abstract but customer is asking if he can correlate external management system metrics and events (net manager) with Dynatrace managed microservice application using Dynatrace AI.
Kind thanks!
Gerards, Igor
Metrics in Custom Network Device are not analysed by AI. You can define custom thresholds for those metrics but they will be static. Yesterday in another question there was info that AI for those metrics is somewhere on roadmap.
Thank you Sebastian!
If anyone knows additional info or time terms please collaborate. I will
greatly appreciate any info.
Strange thing mentioned
Looks like new AI should process custom metrics. Am i understand it correct?
Hmmm looks like you've said... Maybe I've missed this information. Good to know 🙂 But for the purpose I'm using custom metrics AI will not work because data are sent not regularly.
I am asked to confirm if i got it right. We will try to check this funcionality. Sounds very promising...
