Alerting
Drive alert suppression from specific metric events for specific server set
We're monitoring drives (both C and non-C) on windows host using metric events  as below.
Metric event low - threshold (< 10%)
Metric event medium - threshold (<5%)
Metric event high - threshold (<2%)
Now a requirement has come up to suppress only non-C drive alerts which has threshold <10% for specific server set. Is this doable in Dynatrace?
Any thoughts would be helpful.
Srikanth
4 REPLIES 4
If we have separate metric events for C: and Non:C drive, I'd have tagged servers where alerts for low threshold is to be suppressed and filter them out from alerting profile.
Here in this case both C: and Non:C drives are monitored through one metric event.
GosiaMurawska
Community Team
Community Team
Hi @SrikanthSamraj
Have you managed to solve the problem? It would be great if you shared the solution with the Community users 💡
Mizső
Hi @SrikanthSamraj,
Try this new feature from 1.293 OA:
Host monitoring with Dynatrace - Dynatrace Docs
I hope it helps.
Best regards,
Mizső
Thank you @Mizső. But this will require re-engineering entire disk monitoring currently configured. At the moment, we've achieved this at our event management system.
