01 May 2024
		10:06 AM
		07 May 2024
		10:47 AM
hello,
Do we've a scope to export problems into an excel exactly like we've an option for traces?
01 May 2024 10:36 AM
Hello @munawarhossain1
Use the API to download in the .json form and then import in Excel.
Babar
Babar
01 May 2024 10:58 AM
Sorry, I was looking for a simple way! It's tough for everyone into platform to play with API.
Thanks anyways
01 May 2024 11:13 AM
No, not available.
You can open an REF for it or vote for whose is opening the same.
01 May 2024 11:07 PM
I had just raised a similar product idea but it had been discarted.
As others users have already told you, you need to use API, or maybe Grail / DQL / Notebooks.
Best regards
Best regards
02 May 2024 05:01 AM
Dynatrace Services Portal
Add token to Service Tools and Reports>Tokens for your tenant
Observe&Explore>Problems
Export to Excel button
02 May 2024 07:46 AM
Is that portal available for all customers?
Best regards
02 May 2024 08:21 PM
services.dynatrace.com....you might as well try. I am not certain.
