22 Jun 2021
05:04 PM
30 Jun 2021
09:38 PM
Karolina_Linda
We have a number of custom metrics that we would like to pull into Dynatrace in regards to jobs that run for example every 1 hour, 4 hours, 12 hours, once a day and we would like to get alerted if the job doesn't run in that period. The one issue I see for custom alerts is that it only allows a window of 60 minutes. Is this something that Dynatrace would be able to extend?
22 Jun 2021 05:22 PM
Yep this is needed !!!
For similar request (monitor pod that start to run each day at 7:00) we created a small AG plugin that pulls the information with REST API to check if the POD was running today and send the information back to dynatrace with metric API and the custom alert was on the created metric. not so elegant but doing the job 🙂
HTH
Yos
07 Oct 2022 09:33 AM
Hello.
Is there a workaround we can extend the time window check?
23 Jul 2023 08:33 PM
There is a Product Idea that seems to be not planned. But it makes sense to me also, so just letting you know: more votes might be a reason for Dynatrace to reconsider this one.
24 Jul 2023 11:33 AM
Hi @AntonioSousa,
Can you add link to the Product Idea ?
Yos
24 Jul 2023 01:29 PM
Thanks @AntonioSousa , voted!
