07 Jun 2019
02:24 PM
19 May 2021
09:03 AM
Hello.
I'm trying to create a CICS problem dashboard in Dynatrace...
but when I drag the problem Dashlet...Dynatrace creates a panel with all the problems of the environment and not only those of CICS.
07 Jun 2019 02:52 PM
This is actually not possible to have Problems dashlet limited to any filter. Only option i think is to use management zone (Settings - Preferences - Management zone), where you limit visibility of Dynatrace objects via defined filters.
