29 Aug 2024 07:08 AM
Hello All,
Is there a way to add more details to problems where as an example a "Multiple infrastructure problems " problem is created which includes two disks on a same host that are running low on space . When the problem is triggered it only includes the below detail as "2 disks" instead of the including the disk/partition names.
Is it possible to add those details?
29 Aug 2024 07:21 AM - edited 29 Aug 2024 07:22 AM
Hi @p_devulapalli,
You can add entities in the notification:
Or you can create an metric event, which can be extended with entity details and in this case the entities will be listed in the Problem view also:
I hope it helps.
Best regards,
Mizső
29 Aug 2024 08:08 AM
Hi @Mizső
Thanks for the reply, when we use the {ImpactedEntity} or the others it actually displays the host that is impacted by the problem but not the details of the disks that are running on low disk space . What I am after is the details of the disk.
When a problem is generated for a single disk it does show the partition info, but when DT raises a""Multiple infrastructure problems " with two disks it does not display the detail as expected
thanks,
