Is there any way to color code slack notification.
Aamir_khan
Participant
In Hipchat integration open problem notification use be in red and closed in green, by any mean is there any option to do same in slack?
william_littlej
Dynatrace Helper
Dynatrace Helper
Hi Aamir,
Unfortunately, this is not currently possible.
dannemca
DynaMight Leader
DynaMight Leader
Checking if this has some chance to get updated, so we can easily see when a slack message is from a open or closed problem....
Thanks.
