30 Mar 2020
12:58 AM
17 May 2021
03:26 AM
Hi all,
is there a predifined list of "root causes" for problems? Something similar like "event types".
Thank you very much for your help.
Best Regards,
Sonia
Right now Dynatrace Davis does show root-causes on an entity based on events (you have the event types) and on automatically detected metric anomalies (root-cause on a metric without an event).
Both kinds will be exposed in the upcoming v2 of our problem and event API. I expect the new v2 API endpoint to become available in early adopter version around end of May.
Best greetings,
Wolfgang
First of all, thabk you very much for your help, Wolfgang.
On the other hand, onw question: event type is available to be used through API, isn't it?.
Best Regards,
Sonia
