31 Jul 2024
02:32 PM
01 Aug 2024
12:25 PM
Hi, there
Is it feasible to suppress an alert based on metric event and host name? At present, I don't see an option but would like to know if there's any way of getting this done.
Srikanth
31 Jul 2024 11:07 PM
You need to create a maintenance window and define scope.
Best regards
01 Aug 2024 05:25 AM
Hi Srikanth,
Nowadays it's not possible to create maintenance window for a metric events.
There are created these two product ideas:
https://community.dynatrace.com/t5/Product-ideas/Maintenance-Window-for-Metric-Events/idi-p/212834
There aren´t planned for the time being. But on these posts you can find a proposed workaround.
Hope it helps.
Elena.
01 Aug 2024 09:03 AM
Thanks for your response, Elena.
Unfortunately, above links you have shared won't cater my current need. I'll try to explore in the event management system (not in Dynatrace for now).
