13 Oct 2025 11:40 AM
How can we make Management zones selection mandate for Maintenance window addition? I meant without selecting affected management zones It should not be submitted.
This is use case where if anyone forget to mention MZ field by any chance can led to the notification shut Globally.
13 Oct 2025 11:51 AM - edited 16 Oct 2025 04:34 PM
You cannot restrict that in UI, it means, MZ is optional, not mandatory.
You can create your own script / graphical app, outside Dynatrace, setting that field as mandatory. And that script / app will create MZ using API.
Best regards
