30 Nov 2022 05:05 PM
Hi All,
We have requirement to alert on response time, calls/min metric for aggregated services. Is there way we can setup threshold for auto-adaptive and seasonal baseline with % deviation for metric events, similar to what we have in default anomaly alert (response time degradation).
Example
Response Time > Baseline by 100 %
Calls per minute < Baseline <90 %
Suresh
01 Dec 2022 03:54 PM
Hi @SureshThakur ,
thanks for your idea, I appreciate that. I just want to make it clear that you have the possibility to increase the confidence band with "Number of signal fluctuations" - on auto-adaptive or "Tolerance" on seasonal. But yes, it is a good idea, and I will keep that in my mind for further improvement.
thank you very much
best greetings
David
02 Dec 2022 06:58 AM
Thanks @DavidBruendl . Increasing the tolerance band does help tuning the baseline but if we get capability to configure % deviation then it really goanna make difference.
Please let me know if there is some development around it in future.
Suresh
