Alerting
Metric event throttled for disk warning in metric selector
Vijayt
Guide
i have written metric event for disk warning  with metric selector but i am getting metric event throttled ..
1. metric event filters with
   a. host with group / team supporting it
   b. exclude disk with EXCLUDE tag
how to mitigate this
i tried with metric key  but there is no option to filter both entity tag and disk tag
3 REPLIES 3
AntonPineiro
If you are in Grail, best way would be using Davis Anomaly Detector instead.
If you are not in Grail, you need to split it in chunks. But I would recommend using Disk Edge instead of a custom metric event.
Best regards
ours is infra only mode. no grail access. it is not only for disk other metric events as well throws throttled
//you need to split it in chunks.// you mean further  add dimention in split by ?
for example
remote_unix.mount_capacity:filter(and(or(eq(network zone, NW-112)),
or(not(in("dt.entity.remote_unix:host",entitySelector("type(remote_unix:host),tag(~"OS_type:hpux~")")))),
or(in("dt.entity.remote_unix:host_group",entitySelector("type(remote_unix:host_group),entityName.contains(~"remote~")"))))):splitBy("dt.entity.remote_unix:host",mount)
I would suggest using Disk Edge instead. But if you want to use metric events, you need to split by some dimension / tag / hostname...
Best regards
