10 Oct 2019 09:57 PM
When an alert is pushed to a mobile, the mobile will retrieve problem details.
Does he use the standard API for this? but then on port 9999?
https://{your-domain}:9999/e/{your-environment-id}/api/v1/problem/details/{problemId}
(in other words can I test the connection with this link)
KR Henk
11 Oct 2019 07:09 AM
Yes, it uses also this endpoint and also other ones. The port depends on your Cluster ActiveGate configuration and the public address for the Cluster ActiveGate.
