22 Feb 2022
06:17 PM
23 Feb 2022
08:39 AM
Is Dynatrace able to alert on memory utilization of AWS GPU instances (p2.xlarge, for example). Not talking about server memory, but GPU memory.
Hi, do you know if Dynatrace is able to provide such functionalities?
Not out of the box, but can raise a requirement for customize extension. Check this below similar existing extension
