Raise problem
mauricio_capiz
Participant
I'm detecting differences between the number of problems raised vs solved problems. They are not raising the problems that they should.
Is there a reason for this behavior?
I add some examples:
Regards.
4 REPLIES 4
Babar_Qayyum
Hello @mauricio_capiz
Problems that are less severe and have a shorter duration than previous alerts are considered to be frequent issues and so alerts are suppressed for these.
Please have a look at the below link for more insight.
https://www.dynatrace.com/support/help/how-to-use-dynatrace/problem-detection-and-analysis/problem-d...
Babar
Hello @Babar_Qayyum,
Thank you for the quick response
One more question:
If the client does not want this to happen, he wants it to notify all events.
Should I change the automated thresholds to static?
Regards.
You can disable the frequent issues detection.
Babar
Thank you.
I appreciate all the help.
Regards.
