03 Apr 2023
05:37 AM
03 Apr 2023
11:21 PM
Hi Team,
Could you please let me know whether Dynatrace provides a resolution to the raised problems which it raise. If yes please let me know.
I have this client, who wants a resolution or recommended resolution to the Dynatrace problem. We have provided root cause analysis but that is not useful to the apps team.
Appreciate any help here.
Thanks and Regards,
Harmera
Hi @Harmera, not quite yet. Dynatrace correlation of several incidents helps to find a root cause easily but the steps towards resolution relies in the team itself.
Dynatrace does not provide information on how to fix a problem (in the sense of what parameters to change, logic in the code, etc). It provides us with a mass of diagnostic information and the root cause of the problem.
You can find more information here:
https://www.dynatrace.com/support/help/observe-and-explore/davis-ai
Radek
