Alerting
Title of a Problem
mn_24
Organizer
I want to see in the Title of the generated Problem except the hostname but also the Oracle database/instance name - how to do it:
3 REPLIES 3
p_devulapalli
DynaMight Leader
DynaMight Leader
Can you please try adding {entityname}
Phani Devulapalli
Here is what I've done but it is not working...
We need to see not only the hostname from which the problem is coming but also the Instance/Database name. As this is Oracle RAC, the monitoring recognizes all databases there as instances. I can not find a way that both {dt.host.name} and {dt.entity.name}-I am not sure if this is the correct one so this is my first question, because it could also be endpoint.name,dt.source_entity,dt.extension.endpoint.hints,oracle,dn.namespace or other, to be displayed. My second question is how to separate them - tried with "," also with "AND" and even without anything between them but the result is the same - I see the hostname in the title of the generated problem but the second condition seems to be not recognized.
