Dynatrace automatically detects recurring problems. Its good that Dynatrace automatically filters out these problems in the problem view. But sometimes you want to see the recurring problems as well (for optimization purposes for example). Where can I find these recurring problems in one view?
Kind regards,
Chris
Unfortunately, thats not possible so far. You get that info on each entity screen. Could you create a RFE for that with details about the use-cases?
Hi Wolfgang,
Will this be part of the road map? We also have customer here in PH that is looking for this kind of viewing.
Rheena
Any traction on getting this implemented? Haven't seen any updates? thx
