Alerting
is there a way to set custom threshold for individual esxi host ?
MevlutS
Contributor
Hi all ,
Please think that, there is a ESXI host and we want to set higher value for dropped packets threshold. Is there a way to do that ?
Mevlüt
abraham_villega
Dynatrace Participant
Hi Mevlut,
Have you tried creating a custom event? Settings>Anomaly detection> Create custom event for alerting
Here you can define this alert with the following settings:
You can change the thresholds and period evaluation.
Hope this helps!
Abraham
I saw that too, but I dont think that you can apply it just at the ESXI level
-Chad
