Automations
Workflow using process.exit
henk_stobbe
DynaMight Leader
DynaMight Leader
Good morning,
My (workflow) script fetches data in a loop, and when a certain condition is met, the script needs to stop completely. I want to use process.exit for this. Is this a problem?
As an more clear example see below:
let x = 1;
while (x > 0) {
    console.log(x);
    x++;
    if (x > 10) {
        console.log('Exiting...');
        process.exit();
Any problems in this?
KR Henk
christian_kreuz
Dynatrace Mentor
Dynatrace Mentor
As far as I know, process.exit() is not supported by our runtime.
I would recommend doing this via Run JavaScript and "return":
export default async function ({ executionId }) {
  let x = 1;
  while (x > 0) {
    console.log(x);
    x++;
    if (x > 10) {
      return;
henk_stobbe
DynaMight Leader
DynaMight Leader
Hi Christian,
Clear, so if you are in a subroutine  you can only do a return out of that routine to prevent spaghetti (-;
KR Henk
