18 Jan 2026 08:21 PM
Dear all,
Could You help me with an issue? There is an Openshift cluster where when we check the deep monitring for processes then we get this message:
oc get pod <oneagent-pod-name> -o json | jq '.metadata.annotations | keys[] | select(contains("scc"))'The result is the same on both nodes. I stucked with this issue, I don't understand why there is a communication failure between the oneagent and the pod. Alsso we checked the init container and the injection is fine.
Thanks a lot
Kind regards
Peter
