25 Mar 2025 05:03 PM
I have a OneAgent installed on a RHEL machine where a docker server is running.
From there, I can see the running containers, like described here: Monitor container groups — Dynatrace Docs
In the container related metrics, I can't find the availability.
How to be alerted when a container is down ? Is there a specific metric selector ? Perhaps trapping the fact that no performance metrics are capture anymore.
Regards
Gautier
25 Mar 2025 05:31 PM
You can use any metric for the container in the metric event and select "Alert on missing data" option. https://docs.dynatrace.com/docs/shortlink/anomaly-detection-configuration#missing-data
Best Regards
Patryk
