Dynatrace operator 0.14.0 or 0.14.1 issue
Mizső
Hi Folks,
FYI. We have faced an issue at many custormers with Dynatrace Operator. We have received ActiveGate token expiring error at containerized AGs. (Fullstack - Managed)
Operator log:
{"error":"getting reference \"XXXXXXXXXXXXXX/linux/activegate:latest\": Get \"https://XXXXXXXXXXXXX/v2/\": tls: failed to verify certificate: x509: certificate signed by unknown authority","level":"error","logger":"dynakube","msg":"error reconciling DynaKube","name":"dynakube","namespace":"dynatrace","stacktrace":"Get \"https://XXXXXXXXXXXXXXXXX/v2/\": tls: failed to verify certificate: x509: certificate signed by unknown authority
4 hours ago Dynatrace Operator version 0.14.2 released on GITHUB. I hope it will be reached soon via RHEL channel and there will be an official documenatation about it.
Best regards,
Mizső
9 REPLIES 9
radek_jasinski
Hi @Mizső
I also had a similar problem on several environments late last week. The log entry was the same and new certificates had to be generated on the client environment side.
However, I do not know if this is a 1 to 1 problem.
Radek
Have a nice day!
Mizső
Hi @radek_jasinski ,
Thanks for the information. Do you refer to the operator token (former api token)?
Access tokens and permissions - Dynatrace Docs
Thanks in advance.
Best regards,
Mizső
The situation on my client's environment was such that I had to, as I mentioned, generate new certificates (because the client uses its own) and re-generate access tokens. This was happening on a Managed environment.
Have a nice day!
Thanks @radek_jasinski, I am going to try it... 😉
Mizső
Hi Folks,
The problem was:
{"error":"getting reference \"dynatracexxxxxxxxx.hu/linux/activegate:latest\": Get \"https://dynatracexxxxxxxxxx.hu/v2/\": tls: failed to verify certificate: x509: certificate signed by unknown authority"
The solution was:
Creating a config map about the managed DT server cert in the dynatrace project:
Change the dynkube yaml ( skipCertCheck change from true to false and add trustedCAs entry with the above created configmap value) and reload it in the dynatrace project:
I hope it helps.
Best regards,
Mizső
radek_jasinski
Thank you for sharing  this information:)
Have a nice day!
Jorge-salinas
Visitor
Do you know how can fix this same but in GCP?
Hi @Jorge-salinas,
Do you use SaaS Dynatrace form GCP?
Best regards,
Mizső
Yes, I´m trying deploy in GCP GKE
