I'm running a sprint boot application on GKE cluster, and in deployment status-> One agent tab next to my application I'm able to see this
Hi - process monitoring relies on Dynatrace injection into pods - this needs to happen at pod start. So if there were application pods running before deploying Dynatrace, you need to restart these pods in order for injection to happen.
best
florian
I have restarted the pod but still same issue.
please open a ticket with our support 🙂
@niteshkumarrai1 Did you get a chance to see OneAgent log as i had same issue with on of my springboot application in OpenShift cluster where I observed few errors in OneAgent log file like "OneAgent file were infringed" and also in ruxitagent file i observed "failure reason: container injection failed". To fix this I redeployed OA Operator which worked well.
Sujit
@niteshkumarrai1 ahh.. this is bit different then which i had. Good to see it got fixed. btw what was the JVM version which was not being supported.
Sujit
The JVM version was 16.
