26 Nov 2024
03:05 PM
27 Nov 2024
08:19 AM
Hi, i have this error in the installation of the agent on k8:
Warning FailedMount 100s (x15 over 16m) kubelet MountVolume.SetUp failed for volume "oneagent-bin" : kubernetes.io/csi: mounter.SetUpAt failed to get CSI client: driver name csi.oneagent.dynatrace.com not found in the list of registered CSI drivers
can anyone help me please?
27 Nov 2024 06:40 AM
@kevin_ortiz Can you please confirm which Dynatrace operator version your using?
I think there was bug in Dynatrace operator 1.2.0, If your using the same version you can update to 1.2.2
https://docs.dynatrace.com/docs/shortlink/release-notes-dto-fix-1-2-2
27 Nov 2024 09:08 AM
Hi @VenkataSainath , i have the last version available 1.3.2, i put here the output of the operator:
[root@SRV-K8S-M2-PRE ~]# kubectl exec deploy/dynatrace-operator -n dynatrace-pre -- dynatrace-operator troubleshoot
{"level":"info","ts":"2024-11-26T21:49:12.090Z","logger":"version","msg":"dynatrace-operator","version":"v1.3.2","gitCommit":"11b12492182e1f5b896adb4e9feb070373b1865c","buildDate":"2024-10-24T11:00:21+00:00","goVersion":"go1.23.2","platform":"linux/amd64"}
{"level":"info","ts":"2024-11-26T21:49:12.090Z","msg":"logging level","logLevel":"info"}
[oneAgentAPM] --- checking if OneAgentAPM object exists ...
[oneAgentAPM] ✓ OneAgentAPM does not exist
[namespace ] --- checking if namespace 'dynatrace-pre' exists ...
[namespace ] ✓ using namespace 'dynatrace-pre'
[ ] no Dynakube specified - checking all Dynakubes in namespace 'dynatrace-pre'
[crd ] --- checking if CRD for Dynakube exists ...
[crd ] ✓ CRD for Dynakube exists
[dynakube ] --- checking if 'dynatrace-pre:cluster-pre' Dynakube is configured correctly
[dynakube ] using 'dynatrace-pre:cluster-pre' Dynakube
[dynakube ] secret token 'apiToken' exists
[dynakube ] checking if token scopes are valid
[dynakube ] token scopes are valid
[dynakube ] checking if can pull latest agent version
[dynakube ] API token is valid, can pull latest agent version
[dynakube ] pull secret 'dynatrace-pre:cluster-pre-pull-secret' exists
[dynakube ] secret token '.dockerconfigjson' exists
[dynakube ] ✓ 'dynatrace-pre:cluster-pre' Dynakube is valid
[dynakube.imagepull] --- Verifying that OneAgent image jpg94247.live.dynatrace.com/linux/oneagent:1.303.50-raw can be pulled ...
[dynakube.imagepull] ✓ OneAgent image jpg94247.live.dynatrace.com/linux/oneagent:1.303.50-raw can be successfully pulled
[dynakube.imagepull] --- Verifying that OneAgentCodeModules (custom image) image can be pulled ...
[dynakube.imagepull] No OneAgentCodeModules (custom image) image configured
[dynakube.imagepull] --- Verifying that ActiveGate image jpg94247.live.dynatrace.com/linux/activegate:1.303.18-raw can be pulled ...
[dynakube.imagepull] ✓ ActiveGate image jpg94247.live.dynatrace.com/linux/activegate:1.303.18-raw can be successfully pulled
[dynakube.proxy] --- Analyzing proxy settings ...
[dynakube.proxy] ✓ No proxy settings found.
27 Nov 2024 07:26 PM - edited 27 Nov 2024 07:28 PM
Hi @kevin_ortiz
First of all you have to determine the current K8s deployment, is it the accurate method as per Dynatrace best practices and the actual setup or Not:
PFA Dynatrace related resources for detailed level of troubleshooting:
Entry Point to K8s:
The recommended approach:
Simply:
Hoping it helps.
KR,
Peter
27 Nov 2024 07:42 PM
Hello @kevin_ortiz
Peter
14 Feb 2025 12:12 AM
I'm not sure if this is your issue, but we also had this error when we switched from cloud-native full stack to application monitoring. The version we had specified for cloud-native was in the format <major>.<minor>.<release> but application monitoring was expecting <major>.<minor>.<release>.<timestamp>.
