how can i create a dashboard for monitoring pods of an openshift service
nam
Newcomer
I need to create a dashboard for monitor the pods of openshift service. What are the metrics needed for that?
Babar_Qayyum
Hello @nam
There are already three preset dashboards available for the Kubernetes. Please have a look into them and then you clone them to modify them according to your need if they do not fulfill your requirements.
https://www.dynatrace.com/support/help/observe-and-explore/dashboards-classic/dashboards/dashboards-...
Babar
radek_jasinski
Hi @nam
Here you can find all openshift metrics which you can use to create custom dashboards: https://www.dynatrace.com/support/help/platform-modules/infrastructure-monitoring/container-platform...
Radek
Have a nice day!
