k8s problem
Lwl
Helper
If Kubernetes cluster anomaly detection is enabled, will there be additional resource consumption, such as ddu, or cluster node overload
thanks
Islam_Zedan
Champion
Enabling the anomaly detection will not consume any DDUs, and i believe it will not put any load on the cluster node as the data is already collected and analyzed, you can check the below document for further details.
https://docs.dynatrace.com/docs/shortlink/alerts-k8s
Islam
Dynatrace Certified Professional - Dynatrace Partner - Yourcompass.ca
Lwl
Helper
Okay, thank you. I'm worried it might affect the system.
