17 Dec 2025 08:49 AM
Notice that all my oneAgents are named:
dynatrace-oneagent-csi-driver-xxxx
Maybe simple question, but are in the latest version all oneAgents combined with CSI or does this mean CSI driver is detected and this "type" is started.....
Who knows?
KR Henk
17 Dec 2025 10:24 AM
@henk_stobbe those are CSI drivers, not oneagents. Depending on your configuration, those CSI drivers might or might not be used. In a typical scenario, you want to use them. In cloudNativeFullStack, the CSI driver is mandatory, for applicationOnly deployment, it is recommended. See more here.
OneAgents are named after the dynakube name (e.g. dynakube-oneagent), check in the playground environment. ActiveGate has a similar naming.
17 Dec 2025 10:36 AM
Hello Julius,
Thanks for the fast and perfect response!
Thanks Henk🎄
